UC520 some outgoing calls fails
Hi to all,
Last week I installed my first UC520, it works fine (it's a small CCME-CUE), but I have a problem outgoing calls.
Whit some PSTN numbers it seem the UC forward to telco wrong number (because I receive by telco e voice message), it seems that there is not a rules (like prefix or port), if I use a ISDN telephone directly connect to the telco BRI this number, that with UC520 fail, work fine! For expample if I do with ISDN phone the number 02 25478 the is established and works, with UC520 the same number I receive a prompt by telco. Other numbers works fine, other fails!!!
Any ideas? How can I show the number is forwarded to telco BRI? Which is the possible problem?
thank you very much.
voice-port 0/0/0
timeouts ringing infinity
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
compand-type a-law
cptone IT
bearer-cap Speech
voice-port 0/1/1
compand-type a-law
cptone IT
bearer-cap Speech
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Loopback0
sccp ccm 10.1.1.1 identifier 1
sccp
sccp ccm group 1
associate ccm 1 priority 1
dial-peer voice 1 pots
preference 7
service stcapp
port 0/0/0
dial-peer voice 2 pots
service stcapp
port 0/0/1
dial-peer voice 3 pots
service stcapp
port 0/0/2
dial-peer voice 4 pots
service stcapp
port 0/0/3
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 50 pots
preference 7
destination-pattern 0T
incoming called-number 31444444
direct-inward-dial
port 0/1/0
no sip-register
dial-peer voice 51 pots
preference 10
incoming called-number 31555555
direct-inward-dial
port 0/1/1
no sip-register
dial-peer voice 999 voip
description TO_VoiceMail_CUE
destination-pattern 999
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 900 voip
description TO_AutoAttend_CUE
destination-pattern 9..
codec g711ulaw
no vad
telephony-service
video
load 7960-7940 P0030702T023
load 7914 S00104000100
load 7902 CP7902080001SCCP051117A
load 7921 CP7921G-1.0.1
load 7931 SCCP31.8-1-1SR2S
load 7941GE TERM41.7-0-3-0S
load 7941 TERM41.7-0-3-0S
load 7961GE TERM41.7-0-3-0S
load 7961 TERM41.7-0-3-0S
load 7971 TERM70.7-0-3-0S
load 7970 TERM70.7-0-3-0S
load 7936 cmterm_7936.3-3-5-0
load 7906 SCCP11.8-0-3S
load 7911 SCCP11.8-0-3S
max-ephones 14
max-dn 56
ip source-address 10.1.1.1 port 2000
auto assign 10 to 19
auto assign 5 to 8 type anl
calling-number initiator
timeouts interdigit 3
timeouts ringing 120
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
user-locale IT
network-locale IT
time-zone 5
time-format 24
date-format dd-mm-yy
voicemail 999
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
multicast moh 239.10.16.16 port 2000
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern .T
secondary-dialtone 0
create cnf-files version-stamp 7960 Nov 09 2007 08:57:52
Hall of Fame Super Gold
Re: UC520 some outgoing calls fails
Hi Augusto,
first of all with the italian plan you can set so external calls are made without0, just make sure you extensions do not begig with 1, 3, or 8. Generally users will like that is makes more natural to call and recall numbers/
the you can reduce the DPs by placinf the interface in trunk-group
int bri0/x
trunkgroup ti
and use that instead of port in DP:
dial-peer voice 1
desc decade 1,81x
destination-pattern [18]..T
forward-digits all
trunkgroup ti
dial-peer voice 3
desc nazionali
destination-pattern 0[2-9]....T
forward-digits all
trunkgroup ti
dial-peer voice 3
desc internazionali
destination-pattern 00[2-9]....T
forward-digits all
trunkgroup ti
dial-peer voice 0
desc cellulari
destination-pattern ^3[2-4689].......T
forward-digits all
trunkgroup ti
then check which numbers are sent with "debug isdn q931" and "term mon".
Then there are few more customizations, but for now fix this and we'll see more later.
I tryied to implement your configuration but it does not work, when place a new call I obtain always the busy tone. I had removed the "second-dialtone 0", and I keep the "incoming called-number 3144444".
Other idea?
here my sh run:
interface BRI0/1/0
no ip address
isdn switch-type basic-net3
isdn point-to-point-setup
isdn incoming-voice voice
isdn k 7
trunk-group ti
interface BRI0/1/1
no ip address
isdn k 7
interface Vlan1
description $FW_INSIDE$
ip address 192.168.10.1 255.255.255.0
ip access-group 102 in
ip nat inside
ip virtual-reassembly
interface Vlan100
ip address 10.1.1.1 255.255.255.0
ip access-group 103 in
ip nat inside
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
ip http server
ip http authentication local
ip http secure-server
ip http path flash:
ip nat inside source list 1 interface FastEthernet0/0 overload
access-list
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
compand-type a-law
cptone IT
bearer-cap Speech
voice-port 0/1/1
compand-type a-law
cptone IT
bearer-cap Speech
voice-port 0/4/0
auto-cut-through
signal immediate
sccp
sccp ccm group 1
preference 7
service stcapp
port 0/0/0
service stcapp
port 0/0/1
service stcapp
port 0/0/2
service stcapp
port 0/0/3
port 0/4/0
no sip-register
description Nazionali
preference 7
destination-pattern 0[1-9]....T
trunk-group-label target ti
direct-inward-dial
port 0/1/0
forward-digits all
no sip-register
description Internazionali
preference 10
destination-pattern 00[1-9]....T
direct-inward-dial
port 0/1/1
forward-digits all
no sip-register
codec g711ulaw
no vad
codec g711ulaw
no vad
dial-peer voice 52 pots
description Cellulari
destination-pattern ^3[1-4689].......T
forward-digits all
telephony-service
max-ephones 14
max-dn 56
user-locale IT
network-locale IT
time-zone 5
time-format 24
voicemail 999
dn-webedit
time-webedit
transfer-pattern .T
create cnf-files version-stamp 7960 Nov 13 2007 00:37:57
I'm sorry here the right sh run o dial-peer, in this case also without 0 I obtain the same telco promp.
trunkgroup ti
direct-inward-dial
forward-digits all
no sip-register
trunkgroup ti
direct-inward-dial
forward-digits all
no sip-register
trunkgroup ti
forward-digits all
Hi Augusto,
Now enable "debug isdn q931" and "term mon" when making a call, send the output here.
here the output of the isdn debug.
This is one of case when I receive telco prompt.
Thank a lot for your help.
Augusto
Nov 13 11:07:41.401: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Calling num 202
Nov 13 11:07:41.405: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Called num 02962871
Nov 13 11:07:41.405: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8 callref = 0x63
Bearer Capability i = 0x8090
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x8A
Exclusive, B2
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0080, '202'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '02962871'
Nov 13 11:07:41.489: ISDN BR0/1/0 Q931: RX <- SETUP_ACK pd = 8 callref = 0xE3
Channel ID i = 0x8A
Exclusive, B2
Nov 13 11:07:43.365: ISDN BR0/1/0 Q931: RX <- CALL_PROC pd = 8 callref = 0xE3
Nov 13 11:07:43.385: ISDN BR0/1/0 Q931: RX <- DISCONNECT pd = 8 callref = 0xE3
Cause i = 0x84C1 - Bearer capability not implemented
Progress Ind i = 0x8288 - In-band info or appropriate now available
Nov 13 11:07:44.837: ISDN BR0/1/0 Q931: TX -> RELEASE pd = 8 callref = 0x63
Nov 13 11:07:44.881: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xE3
Hi Augusto,
I had forgot the most important thing. Please configure:
voice-port 0/0/0
compand-type a-law
Also you don't need "k 7" under BRI interfaces.
this is the translation-profile to add zeros for recall. Use it under the trunkgroup for incoming:
voice translation-profile ti-tg-in
translate calling 100
voice translation-rule 100
rule 1 // /0/ type national national
rule 2 // /00/ type international international
The voice port was already configured with compand-type and cptone
voice-port 0/1/0
compand-type a-law
cptone IT
bearer-cap Speech
voice-port 0/1/1
compand-type a-law
cptone IT
bearer-cap Speech
From isdn output it seems that CCME sent right number to telco BRI, right?
Thank for traslation rules.
Thank a lot.
Augusto
Hi Augusto,
The number is right but bearer capability sent is not like should be:
Nov 13 13:52:36.091 CET: ISDN BR0/2/0 Q931: TX -> SETUP pd = 8 callref = 0x3B
Bearer Capability i = 0x8090A3
Standard = CCITT
Channel ID i = 0x89
Exclusive, B1
Calling Party Number i = 0x0080, '28'
Called Party Number i = 0x80, '187'
Sending Complete
Nov 13 13:52:36.163 CET: ISDN BR0/2/0 Q931: RX <- CALL_PROC pd = 8 callref = 0xBB
Channel ID i = 0x89
Exclusive, B1
I always used "isdn sending-complete" alos, see if it helps.
Hi to all,
my problem is a bug in UC520 IOS 12.4(11)XW, I resolved it download and upgrade the IOS to 12.4(11)XW4, now it works fine!
Thank for your patient.
Augusto.
Just the thing that I wanted to say and then I did not :)
Please come back at any time, thanks, Paolo.
242
