UC520 turned into a brick during CCA upgrade
patrick.hurley
Level 3
Level 3
It seems that when going through an upgrade, if CCA hangs, its already deleted the IOS and now when I reboot the UC520, its a brick. How do I get the IOS back on the flash?
When you type it without parameter, it shows the environment variables that you have to set, like IP_ADDRESS=10.10.10.10
When all variable are set correctly, it will proceed to copy file to flash, or there is an option to only load image and boot.
7 Replies 7
paolo bevilacqua
Connect serial console. Boot and report output here.
Its in rommon mode. there is a command tftpdnld that I can use but haven't been able to figure out the syntax.
It says line too large. Catch22
Can you type an example that actually works? I cannot find the right string.
I figured it out. Thanks!
You're welcome. Please remember to rate useful posts with the scrollbox below.
