UC520 turned into a brick during CCA upgrade
It seems that when going through an upgrade, if CCA hangs, its already deleted the IOS and now when I reboot the UC520, its a brick. How do I get the IOS back on the flash?
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: UC520 turned into a brick during CCA upgrade
When you type it without parameter, it shows the environment variables that you have to set, like IP_ADDRESS=10.10.10.10
When all variable are set correctly, it will proceed to copy file to flash, or there is an option to only load image and boot.
Connect serial console. Boot and report output here.
Its in rommon mode. there is a command tftpdnld that I can use but haven't been able to figure out the syntax.
It says line too large. Catch22
Can you type an example that actually works? I cannot find the right string.
I figured it out. Thanks!
You're welcome. Please remember to rate useful posts with the scrollbox below.
157
