UC520
Hi. I need configure the FXS port, in the Cisco UC520. The Cisco Configuration Assistant show error messages, and I would like configure the analog phone from the CLI .. I can configure the analogic phone connected to FXS from the CLI ??? How I can do it??
thanks
Hall of Fame Super Gold
Re: UC520
If you want dual-line and features, follow the guide for "FXS port in SCCP mode" that is contained in the administration guide. In fact, the UC520 do come pre-configured for that already.
Else, configure a regular pots DP pointing to the port, that is enough.
Re: UC520
Thanks. p.bevilacqua
I want configure single line in the analog phone. The configuration of the FXS is empty, as following:
voice-port 0/0/0
Re: UC520
Check if the port actually register as ephone. Recommend you configure as SCCP mode so the will be able to transfer calls, a common request.
It's all explained in the guide, you will either read it, or give the job to a professional.
Re: UC520
I resolve my problem :D
voice-port 0/0/0
station-id name Phone01
station-id number 800
dial-peer voice 800 pots
destination-pattern 800
port 0/0/0
:D
Re: UC520
Sure, but be prepared to answer "you can't" when user ask "how do I transfer a call ?".
Re: UC520
you are right, but I dont know to enable SCCP in FXS port :(
(How could I know the MAC address of the FXS)
p.bevilacqua
Re: UC520
In the manual it tells you how, with clear examples. Also, the default configuration file for UC520 has all the commands in there already.
Leave auto-registration on, the port registers and you see the mac with "show ephone".
881
