Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
UC520W Integrated Wireless
I tried to configure the integrated wireless by using CCA. I sat around waiting for the SSID to show up on my laptop and it never did. Do I have to configure something at the command line?
Hall of Fame Super Red
Re: UC520W Integrated Wireless
Hi Patrick,
I'm not familiar with the UC520W but on most AP's the SSID has to be set to "guest mode" to be able to broadcast the SSID. Have a look for this setting. You may find some additional info here;
SBCS:Documentation - Cisco Smart Business Communication Systems - Ciscowiki
http://supportwiki.cisco.com/ViewWiki/index.php/Category:Documentation_-_Cisco_Smart_Business_Communication_Systems
Hope this helps!
Rob
It has a broadcast SSID check box which is checked.
142
