Community Member
UC540 - 7970 phone - Redial, add 9
When checking missed calls and pressing 'dial' to call the number missed, the system does not add a 9 to allow the call to be placed to the destination. I've been searching on how to adjust this and I haven't found a very clear answer. I am using CCA but I am comfortable in the CLI as well. Any ideas?
Thanks!
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Nathan,
You can check out these good threads
https://supportforums.cisco.com/message/3417227#3417227
https://supportforums.cisco.com/message/3083663#3083663
Cheers!
Rob
"May your heart always be joyful
And may your song always be sung
May you stay forever young "
- Dylan
Hi Nathan,
Cheers!
Rob
- Dylan
Community Member
Thanks for the links. I've applied the changes and I'm waiting on feedback for the fix.
170
