Uc540 External Access for Voicemail
Nathan Hardman
Hi Everybody,
I have a customer who wants to be able to access their voicemail, when they are out of the office.
I have tried setting up a number without voicemail and put a call forward all to voicemail but then it states there is no voicemail box setup for this user.
Could anybody please tell me how i go about completing this
Nathan
ronpatel
Level 8
Level 8
Hi Nathan,
If you will go to configure -> users and extensions -> voicemail.  A windows should
then appear and you can add a PSTN DID for outside Voicemail access.
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
ronpatel
Level 8
Level 8
Hi Nathan,
Ronak Patel
paolo bevilacqua
Which type of PSTN circuits do you have? Do you have DID ?
Nathan Hardman
Hi Ronak,
There is a Voicemail Access PSTN Number but this is a blue field and won't let me type a number in it.
Hi Paolo,
Im using SIP but i have this is a staging lab at the min. Yes i have a DID that can be used
Nathan
Nathan Hardman
When i changed the voicemail DDI to a number in their range it automatically populated the external pstn number. My next problem is it asks for the user ID yet i don't know how the phone enters the digits.
Nathan
