Community Member
UC540 Message Waiting Indicator Not Working with Software Pack 8.2.0
I have a UC540 that I have recently upgraded to software pack 8.2.0.  I amhaving problems with the message waiting indicator not coming ON when a new message is received.  I seems to be happening with all the phones at this time.  I configured the system with CCA 3.1.1 and am not aware if it ever worked on this system.  The message is in the mailbox but I am not getting an indication of the new message.
The configuration is as follows:
ephone-dn  299
number A801... no-reg primary
mwi off
ephone-dn  300
number A800... no-reg primary
mwi on
In CUE:
ccn application ciscomwiapplication aa
description "ciscomwiapplication"
enabled
maxsessions 6
script "setmwi.aef"
parameter "CallControlGroupID" "0"
parameter "strMWI_OFF_DN" "A801"
parameter "strMWI_ON_DN" "A800"
end application
What else do I need to check?  How can I test this?
Hi there,
Upload the show run from UC540 and from CUE and I'll look at it.
Luis Ramirez.
Community Member
Re: UC540 Message Waiting Indicator Not Working with Software Pa
Attached
Configuration looks good.
I think the CUE is generating the call to turn MWI on but there is no dial-peer able to receive it and that is what is causing the issue.
The only way to confirm that would be getting debugs but lets try first to force the call to match the desired incoming dial-peer.
Try this.
dial-peer voice 2000 voip
incoming called number A80....
end
Please rate this post if it was helpful.
Luis Ramirez
Community Member
Sorry, that did not fix it.  Here is what I put in:
dial-peer voice 2001 voip
incoming called-number A80....
If I test the pattern:
rec_calgary#sh dialplan number A801601
Macro Exp.: A801601
VoiceEncapPeer20003
        peer type = voice, system default peer = FALSE, information type = voice,
        description = `',
        tag = 20003, destination-pattern = `A801...',
        voice reg type = 0, corresponding tag = 0,
        allow watch = FALSE
        answer-address = `', preference=0,
        CLID Restriction = None
        CLID Network Number = `'
        CLID Second Number sent
        CLID Override RDNIS = disabled,
        rtp-ssrc mux = system
        source carrier-id = `', target carrier-id = `',
        source trunk-group-label = `',  target trunk-group-label = `',
        numbering Type = `unknown'
        group = 20003, Admin state is up, Operation state is up,
        incoming called-number = `', connections/maximum = 0/unlimited,
        DTMF Relay = disabled,
        URI classes:
            Destination =
        huntstop = enabled,
        in bound application associated: 'DEFAULT'
        out bound application associated: ''
        dnis-map =
        permission :both
        incoming COR list:maximum capability
        outgoing COR list:minimum requirement
        Translation profile (Incoming):
        Translation profile (Outgoing):
        incoming call blocking:
        translation-profile = `'
        disconnect-cause = `no-service'
        advertise 0x40 capacity_update_timer 25 addrFamily 0 oldAddrFamily 0
        mailbox selection policy: none
        type = pots, prefix = `',
        forward-digits 0
        session-target = `', voice-port = `50/0/299',
        direct-inward-dial = disabled,
        digit_strip = enabled,
        register E.164 number with H323 GK and/or SIP Registrar = FALSE
        fax rate = system,   payload size =  20 bytes
        supported-language = ''
        preemption level = `routine'
        bandwidth:
            maximum = 64 KBits/sec, minimum = 64 KBits/sec
        voice class called-number:
            inbound = `', outbound = `'
        dial tone generation after remote onhook = enabled
        mobility=0, snr=, snr_noan=, snr_delay=0, snr_timeout=0
        Time elapsed since last clearing of voice call statistics never
        Connect Time = 0, Charged Units = 0,
        Successful Calls = 1, Failed Calls = 0, Incomplete Calls = 0
        Accepted Calls = 0, Refused Calls = 0,
        Last Disconnect Cause is "10  ",
        Last Disconnect Text is "normal call clearing (16)",
        Last Setup Time = 243754.
        Last Disconnect Time = 0.
Matched: A801601   Digits: 4
Target:
Here is a ccsip debug when I leave a message for x605
008018: Nov  8 18:20:10.330: //60/20BDD7D480B0/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:699@10.6.0.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.6.0.2:5060;branch=z9hG4bK222317
Remote-Party-ID: "Name" <604>;party=calling;screen=no;privacy=off
To: <699>
Date: Tue, 08 Nov 2011 18:20:10 GMT
Call-ID: 20BE73FC-96D11E1-80B4B214-AEA71E37@10.6.0.2
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 0549312468-0158142945-2159063572-2930187831
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1320776410
Contact: <604>
Diversion: <605>;privacy=off;reason=no-answer;counter=1;screen=no
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 235
v=0
o=CiscoSystemsSIP-GW-UserAgent 4068 1902 IN IP4 10.6.0.2
s=SIP Call
c=IN IP4 10.6.0.2
t=0 0
m=audio 18678 RTP/AVP 0 101
c=IN IP4 10.6.0.2
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
008019: Nov  8 18:20:10.338: //60/20BDD7D480B0/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <699>
CSeq: 101 INVITE
Content-Length: 0
008020: Nov  8 18:20:10.402: //60/20BDD7D480B0/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <699>;tag=dsb5462a6d
CSeq: 101 INVITE
Content-Length: 0
Contact: <699>
Allow: INVITE, BYE, CANCEL, ACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO
Cisco-Gcid: 20BE73FC-96D11E1-80B4B214-AEA71E37@10.6.0.2
008021: Nov  8 18:20:10.474: //60/20BDD7D480B0/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 101 INVITE
Content-Length: 181
Contact: <699>
v=0
o=CUE 6857881 2 IN IP4 10.6.0.1
s=SIP Call
c=IN IP4 10.6.0.1
t=0 0
m=audio 21044 RTP/AVP 0 101
a=fmtp:101 0-15
008022: Nov  8 18:20:10.494: //60/20BDD7D480B0/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:699@10.6.0.1:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.6.0.2:5060;branch=z9hG4bK23491
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
008023: Nov  8 18:20:16.242: //60/20BDD7D480B0/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:699@10.6.0.1:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.6.0.2:5060;branch=z9hG4bK241F08
Max-Forwards: 70
Timestamp: 1320776416
CSeq: 102 BYE
Reason: Q.850;cause=16
Content-Length: 0
008024: Nov  8 18:20:16.254: //60/20BDD7D480B0/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 102 BYE
Content-Length: 0
Is that all you got from debug CCSIP messages?
I don't see the CUE sending the call for MWI.
try this on CUE.
ccn subsystem sip
mwi sip outcall
exit
Try getting the debugs ccsip again but don't leave the voice mail.
Do a "mwi refresh all" on CUE so it sends the calls for MWI to CME foe the voicemails that are already in CUE.
Luis Ramirez.
Community Member
"mwi refresh all" did not make any difference.
Can't do a "ccn subsystem sip"
se-10-6-0-1# ccn ?
  call              Active call related information
  copy              Copy data from one location to another
  delete            Remove data
  rename            Rename a local data file
  reporting         historical Reporting
  trace             Trace
se-10-6-0-1# ccn
Here is debug when I do NOT leave a message.  I let it go to VM, but disconnected when I heard the prompt.
rec_calgary#
008084: Nov  8 18:55:57.742: //71/20B2FDCD80D3/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.6.0.2:5060;branch=z9hG4bK2B24F1
To: <699>
Date: Tue, 08 Nov 2011 18:55:57 GMT
Call-ID: 20B399F5-97211E1-80D7B214-AEA71E37@10.6.0.2
Min-SE:  1800
Cisco-Guid: 0548601293-0158470625-2161357332-2930187831
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1320778557
Contact: <604>
Expires: 180
Content-Length: 233
v=0
o=CiscoSystemsSIP-GW-UserAgent 880 334 IN IP4 10.6.0.2
s=SIP Call
c=IN IP4 10.6.0.2
t=0 0
m=audio 17872 RTP/AVP 0 101
c=IN IP4 10.6.0.2
a=fmtp:101 0-16
a=ptime:20
008085: Nov  8 18:55:58.242: //71/20B2FDCD80D3/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <699>
Date: Tue, 08 Nov 2011 18:55:58 GMT
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1320778558
Contact: <604>
Expires: 180
Content-Length: 233
v=0
s=SIP Call
c=IN IP4 10.6.0.2
t=0 0
c=IN IP4 10.6.0.2
a=fmtp:101 0-16
a=ptime:20
008086: Nov  8 18:55:58.686: //71/20B2FDCD80D3/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <699>
CSeq: 101 INVITE
Content-Length: 0
008087: Nov  8 18:55:58.710: //71/20B2FDCD80D3/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <699>
CSeq: 101 INVITE
Content-Length: 0
008088: Nov  8 18:55:58.742: //71/20B2FDCD80D3/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <699>;tag=ds2cb4f267
CSeq: 101 INVITE
Content-Length: 0
Contact: <699>
Cisco-Gcid: 20B399F5-97211E1-80D7B214-AEA71E37@10.6.0.2
008089: Nov  8 18:55:58.814: //71/20B2FDCD80D3/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 101 INVITE
Content-Length: 181
Contact: <699>
v=0
o=CUE 9006201 2 IN IP4 10.6.0.1
s=SIP Call
c=IN IP4 10.6.0.1
t=0 0
m=audio 20894 RTP/AVP 0 101
a=fmtp:101 0-15
008090: Nov  8 18:55:58.834: //71/20B2FDCD80D3/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.6.0.2:5060;branch=z9hG4bK2C7D8
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
008091: Nov  8 18:56:02.971: //71/20B2FDCD80D3/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.6.0.2:5060;branch=z9hG4bK2D1812
Max-Forwards: 70
Timestamp: 1320778562
CSeq: 102 BYE
Content-Length: 0
008092: Nov  8 18:56:02.979: //71/20B2FDCD80D3/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 102 BYE
Content-Length: 0
The CCn subsystem Sip is in config mode.
don't call voicemail, just enable the debugs and run the command "MWI refresh all" in CUE.
Also get this show command fom CUE.
show voicemail maboxes
Luis Ramirez,
Community Member
Sorry.  Here it is.
No difference with the:
ccn subsystem sip
mwi sip outcall
exit
rec_calgary#sh debug
CCSIP SPI: SIP Call Message tracing is enabled  (filter is OFF)
rec_calgary#ser int 0/0 sess
Trying 10.6.0.2, 2002 ... Open
banner login ^Cisco Configuration Assistant. Version: 3.1 (1). Fri Nov 04 13:23:02 MDT 2011^
se-10-6-0-1#
se-10-6-0-1#
se-10-6-0-1#
se-10-6-0-1# mwi ref
se-10-6-0-1# mwi refresh all
se-10-6-0-1# sh voicem ma
se-10-6-0-1# sh voicem mailboxes
OWNER               MSGS NEW SAVE DEL BCST FUTR FAX MSGTIME   MBXSIZE  USED
"TPhone"            5    5   0    0   0    0    0   18        720      3 %
"xmmm"              0    0   0    0   0    0    0   0         720      0 %
"xm.1"              0    0   0    0   0    0    0   0         720      0 %
"xm.a"              0    0   0    0   0    0    0   0         720      0 %
"xm.d"              0    0   0    0   0    0    0   0         720      0 %
"xm.g"              0    0   0    0   0    0    0   0         720      0 %
se-10-6-0-1#
That confirms that the CUE is not generating the MWI call.
Configuration on CUE looks fine since the application and the trigger are enabled and and have max sessions.
You might try doing this on CUE.
conf t
ccn trigger http urlname mwiapp
maxsessions 6
exit
Then reload the CUE to see if that makes any difference.
If that does not work, you'll need to capture some CUE traces by doing this in CUE.
no trace all
clear trace
trace voicemail all
After that, try leaving a call and then in order to get the traces do this.
show trace buffer tail.
Hope this helps.
Luis Ramirez,
Community Member
Did this:
application "ciscomwiapplication"
enabled
maxsessions 6
end trigger
I then reloaded.  No difference.  Here is the trace.
se-10-6-0-1# no trace all
se-10-6-0-1#
se-10-6-0-1# clear trace
se-10-6-0-1# show trace buff tail
Press to exit...
se-10-6-0-1#
se-10-6-0-1#
se-10-6-0-1#
se-10-6-0-1#
se-10-6-0-1#
se-10-6-0-1#
se-10-6-0-1#
se-10-6-0-1# trace voicemail all
Press to exit...
3443 11/08 14:12:20.347 voicemail debug "dbg" com.cisco.aesop.voicemail.Mailbox : No session 8000000015 to logout
se-10-6-0-1#
try again with the show trace buffer tail.
It takes a while come up.
Luis Ramirez.
Community Member
Trace uploaded.
Seems like it is actually trying it but you have your ccn subsystem sip pointing to 10.1.10.2.
Change that to the real gateway.
conf t
ccnsubsystem sip
gateway address 10.6.0.2
exit
After that, try again that should help.
Luis Ramirez
Community Member
Sorry for the delay.  I have entered:
ccn subsystem sip
gateway address "10.6.0.2"
dtmf-relay rtp-nte
end subsystem
Still having the same problem though.
1313
