UC540 paswword damaged
I was using for almost 18 months the CCA v3.x very well (upgraded two times the previous versions), 3 months ago and I started sharing configurations and settings with the Cisco SB Office Manager, yesterday after enabling the VPN for a user in the CSBOM and later changing some configs, when closing the CCA, it reported an error saving the configs and the password that I was using for so long its invalid in the CCA and in the CSBOM that never asked for a password after the initial configuration is asking not only for login/password BUT also for an "Enable Password" field.
QUESTIONS:
Can the password be reset without loosing the actual config ?
What is "Enable Password"
HB
  • IP Telephony
Everyone's tags (1)
1 REPLY
Hall of Fame Super Gold
Wrong forum, post in "small business - UC500". You can move your post with the actions panel on the right.
208
