UC540 Phone Licensing
On the UC540 platform, how exactly is licensing done?  If you get a 8 phone license on the defualt kit, my understanding is that this gives you 8 IP phones, 2 teleworker phones, and 4 FXS ports.  So you can technically have 10 IP phones along with 4 Analog for a total of 14 phones (IP and analog) operating at once...is that correct?  Is there some limitation with the teleworker phones?
Now, I understand on CME that there is no hard limit to the amount of ephones and DNs, does this change for the UC540?  Does it limit you to the 8+2 and you can't go higher without a license?
Re: UC540 Phone Licensing
What's teleworker phones? How calculate the phone numbers?
Hall of Fame Super Red
Hi Rob,
Here are the Licensing references. If you need to go above the base license you
would need to add/order the 8-User upgrade;
Licensing
The Cisco UC 540 includes eight user licenses. These licenses enable the use of
Cisco Unified IP Phones and allow users to access the IP PBX features, including
voicemail. In addition, supplementary user licenses are bundled to help with
deployments that need a few extra licenses. For additional licensing needs,
the L-UC-PRO-8U= may beordered. This increases the existing license count
by eight. Table 5 lists the number of users supported based on the hardware/license
configurations. The UC 540 also has built-in licenses for unified communications features.
Table 4 lists the license count bundled within the system for each feature.
Table 4. Licensing and User Capacity for the Cisco UC 540
License Configuration Description
UC540W-FXO-K9 or UC540W-BRI-K9 8 user licenses, 2 supplemental user licenses
UC540W-FXO-K9 or UC540W-BRI-K9 and one L-UC-PRO-8U= 16 user licenses, 2 supplemental user licenses
UC540W-FXO-K9 or UC540W-BRI-K9 and two L-UC-PRO-8U= 24 user licenses, 4 supplemental user licenses
UC540W-FXO-K9 or UC540W-BRI-K9 and three L-UC-PRO-8U= 32 user licenses, 4 supplemental user licenses
Table 5. Feature Licensing for the Cisco UC 540
Feature Number of Licenses Included
Virtual LANs (VLANs) 5
Service Set Identifiers (SSIDs) 3
Broadcast SSIDs (BSSIDs) 1
VPN tunnels* 10
Remote teleworker sites 10
Users per teleworker site 5
Multisite deployments 5
http://www.ciscocapital.info/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps7293/C78-557768-00_540_platform_reference_guide_DS_v2a.pdf
For CME the number of supported phones is based on the Router platform and Memory.
For example: Here is the number for a 2811,2821 and 2851 with CME;
Cisco 2811
Maximum Total IP Phones 36
Cisco 2821
Maximum Total IP Phones 48
Cisco 2851
Maximum Total IP Phones 96
Hope this helps!
Rob
2577
