rln
UC560 - Emergency or Site Closure Message
Hi All,
We have recently implemented a Cisco UC560. We have setup an auto attendant among other things successfully.
I would like to know if there is a fairly easy way to put emergency or closure messages on the auto attendant. For example if we are closed due to bad weather etc... without having to go in and change lots of config. We will of course have .wav files pre-recorded and ready.
Any help would be much appreciated.
Richard
Hall of Fame Super Red
Hi Richard,
I think the AVT from the lab is what you want
Configuring_AvT_for_Remote_Access_with_CCA.pdf
(527.8 K)
View
Download
and this set of labs;
https://supportforums.cisco.com/docs/DOC-9836
Cheers!
Rob
"Why do the best things always disappear "
- The Band
rln
Re: UC560 - Emergency or Site Closure Message
Hi Rob,
This is really useful - thanks.
But can this only be done from an extension connected to the UC or rung in from an external phone?
......But, at this stage I don't need a user to be able to do this just yet, I just need to do it myself via CCA or via the web interface for the UC.
Is it actually as simple as changing the sound file loaded for day and the one for night? Or is there a better way to be doing it?
Richard
Hi Richard,
I prefer phone just in case I don't have access due to circumstances
(I might be at the bar ) but you can also do it as simply as you noted
by temporarily replacing the Night or Day greeting files. You might also
check into the Alternate Greeting tweak mentioned in the lab
Cheers!
Rob
- The Band
rln
Hi Rob,
I had a go with the AvT and setup the extension to call in to. It worked and I got the options to record a alternate message. But when I then called the switchboard auto attendant it did not seem to have applied. Going to have another go in a bit but should it just be that simple?
Richard
Hi Richard,
If it's not playing you need to look at the aa.script versioning
as discussed in this good thread
https://supportforums.cisco.com/thread/2122092
Cheers!
Rob
- The Band
rln
Hi Rob,
Looks like that might be it, I have the V03 script by the looks of it. Have you changed yours before? Any pointers?
I assume its a simple upload and reset option buttons if required? Do the open/closed sound files stay the same along with everything else?
Richard
rln
Hi Rob,
Also further to my last post, if I look at the drop downs for the scripts it looks like I have a 04 one there as well. See attached acreen shot.
Richard
Hi Richard,
Unfortunately I don't have a uc5xx box in the lab right now to
do any testing of this to try & help you further. Why don't you go ahead and
move the whole thread over to the uc500 section of the forums
https://supportforums.cisco.com/community/netpro/small-business/voiceandconferencing/sbcs-uc500
There are some great peeps there that can verify the steps for you.
- The Band
rln
Apologies Rob.
I didn't realise this was the wrong forum.
I have however in the interim logged a case with support to look at amending my script and to take some further advice.
Thanks again for all your help!
Richard
Hey Richard,
No worries my friend There is no such thing
as the right or wrong areas here @ CSC as everyone
is only here to help.
Cheers! And best of luck getting this set up (snow days are coming...at least here)
Rob
- The Band
236
