UC560 Fax rate question.
AdmShatan
I have set up fax to email on my UC560, though recently switched vendors for our telephony service.  I thought it was going to be a straigh pri-pri switch, but it was not.  I'm being asked to set my system to receive at 9600bps.  Is there a way to do that in the UC500 series?
I had previously set up my uc560 to do fax to email, sample config here with one of the did dial peers:
fax receive called-subscriber $d$
fax interface-type fax-mail
mta send server 10.1.10.1 port 25
mta send with-subject both
mta send mail-from hostname 10.1.10.2
mta send mail-from username $s$
mta receive aliases 10.1.10.2
mta receive maximum-recipients 7
application
service cca_fax_detection flash:/applications/faxmail/app_fax_detect.2.1.2.2.tcl
  param fax-dtmf 2
  param mode listen-first
  param voice-dtmf 1
  param prompt flash:/applications/faxmail/en_listen_first.au
service cca_offramp flash:/applications/faxmail/app_faxmail_offramp.2.0.1.1.tcl
service cca_onramp flash:/applications/faxmail/app_faxmail_onramp.2.0.1.3.tcl
dial-peer voice 3016 pots
description 5017_T37
translation-profile incoming 5017_T37_Called_21
service cca_onramp
incoming called-number 5017
direct-inward-dial
port 0/3/0:23
voice translation-profile 5017_T37_Called_21
translate called 21
voice translation-rule 21
rule 1 /5017/ /208/
5 Replies 5
paolo bevilacqua
I don't think one can set speed for receiving in T.37 mode. Can you please post "show controllers T1".
Paolo:
T1 0/3/0 is up.
  Applique type is Channelized T1
  Cablelength is long gain36 0db
  No alarms detected.
  alarm-trigger is not set
  Soaking time: 3, Clearance time: 10
  AIS State:Clear  LOS State:Clear  LOF State:Clear
  Version info Firmware: 20100222, FPGA: 13, spm_count = 0
  Framing is ESF, Line Code is B8ZS, Clock Source is Line.
  CRC Threshold is 320. Reported from firmware  is 320.
  Data in current interval (490 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Total Data (last 24 hours)
     136 Line Code Violations, 3 Path Code Violations,
     5 Slip Secs, 0 Fr Loss Secs, 1 Line Err Secs, 1 Degraded Mins,
     6 Errored Secs, 1 Bursty Err Secs, 0 Severely Err Secs, 12797 Unavail Secs
So it seem network-clock is set right... You should be able to receive fine.
Faxes to the DID's that have the service cca_onramp don't work.  The UC picks up the call, and sends negotiation tones, but we can't receive.
Can you take some debugs. I think these are of the form debug mta, but do not have reference here. It is actually quite difficult to find fax debugs commands, but you can start checking if it is an email problem.
