Community Member
UC560 REMOTE PHONES
Hi All,
could you please tell me what are the options  to connect Remote phones (1 per site) to the Central UC560? I am at the design step
What do I need for  the remote sites?
REGARDS
GCA
Everyone's tags (3)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
UC560 REMOTE PHONES
Router to create VPN. Better if these, or the switches, have PoE.
UC560 REMOTE PHONES
Community Member
UC560 REMOTE PHONES
Now I got that the 7945 can connect by VPN with an ASA to the CME8.x
What I don´t know is it is enough with the ASA Essential VPN License :
ASA-AC-E5505
Anny Connect Essential vpn license    ASA 5505 25 user
Or if it is nescesary the premium one:
ASA5500-SSL-25
ASA   5500 SSL VPN 25 Premium User License
I Appreciate your help,
regards
Re: UC560 REMOTE PHONES
You would need the SSL VPN licenses.
Even better, use a router instead of ASA, and need no licenses.
Note: doing phone VPN is very ver complicated and poorly documented. Better to place a small router at the remote site instead.
430
