UCCX 9.0 Subcriber
Dears,
I get a attached error while installing uccx 9.0 subsciber, I tried 2 times it stops with the same error. Any other way to install subscriber.
1 ACCEPTED SOLUTION
Re: UCCX 9.0 Subcriber
Hi which hardware did you reserved for thath server.
Did you check if installation image is somehow corrupted?
Carlo
Please rate all helpful posts "The more you help the more you learn"
Carlo
UCCX 9.0 Subcriber
Hello Carlo,
+5
I was installing by ISO in datastore and unfortunately that was corrupted, when  i boot from DVD it was perfect installation.
119
