uccx agents with two icd extension ?
Hi all, i have the following scenario:
agent1 has to worked in CSQ_1 and CSQ_2 depending o the day of the week.
For achieve this, i have created two extension mobility profile, one for CSQ_1 and one for CSQ_2. To reduce login/password/extension remindings, i was thinking of using just one profile with 2 buttons, one for each CSQ. The problem is that an agent can only have one ICD extension...
Does the agent will be able to log into the CAD with this configuration ?
(He could select the good extension depending on the CSQ he has to worked when login...)
Thanks a lot for your advises !
1 REPLY
Hall of Fame Super Silver
Re: uccx agents with two icd extension ?
No, becuse an agent can be identified with only one ICD extension and the other one will not be usable.
Your best solution is to use 2 EM profiles.
Chris
142
