UCCX doesn't show all the services after reboot
I have the following strange issue, UCCX in HA over WAN, we had a WAN failure during the weekend. We restarted both UCCX and everything looks OK, except in the Subsystem Manager I see only 4 services:
Unified CM Telephony Subsystem
Core RTR Subsystem
CMT Subsystem
RmCm Subsystem
Instead of the usual
MRCP ASR Subsystem
Core RTR Subsystem
CMT Subsystem
eMail Subsystem
RmCm Subsystem
MRCP TTS Subsystem
Voice Browser Subsystem
HTTP Subsystem
Outbound Subsystem
VOIP Monitor Subsystem
Database Subsystem
This was after the cluster reboot.
System version: 8.5.1.11001-35
So I'm wondering if someone faced this problem before.
After the reboot, are you able to see the Master (M) and Slave (S) against few of these services, i am just trying to see here if the node1 and node2 are in sync and not in Island mode (where both the nodes are working independently as master nodes).
Could you please attach the snippet of expanded view of the subsystem of the control center of both the nodes.
Anand
Hall of Fame Super Silver
It looks like your licenses are no longer Premium, did you by any chance upload either Standard or Enhanced licenses and did not do system restart after-wards some time ago?
Chris
Thanks for the info. Here are the screenshot, the currently Package: Cisco Unified CCX Enhanced
Now I have the doubt if they used to have Premium or not. I will double-check.
Those subsystems are only available with Premium edition, so my safe bet here is license has been overwritten with Enhanced edition, perhaps new Enhanced agent licenses were added instead of Premium which would overwrite previous Premium agents.
HTH,
Chris
Hey Guys,
Thanks for the answer, I just check another UCCX with the Enhanced license and looks like this one.
Usually most of our customers has Premium, so probably I had in my head the other config.
Anyways thanks for the support.
290
