Community Member
UCCX Process DIsable
Hi Everebody
I am installing the  Unified CCX - but I am CRS Administration an CRS Engine Process are always going to DISABLE mode. Does any body now how can I fix this issue
Other question concerning the  "CRS Admin Utily" - What is the user name and password ?
Re: UCCX Process DIsable
In order toi know why the engine is going into partial service you will need to check the MCVD trace, those are in C:\Program Files\Wfavvid\Log
MCVD
Community Member
Hi Antonio,
What is the version of UCCX???
Best regards.
Mauricio
Community Member
Hi Mauricio
I using the
Version5.0(2)_Build064
I am puting some MCDV trace log
233
