UCM 4.1 found information in traces...
I have CM 4.1 with detailed CM traces enabled...
I have touble with hunt pilot/group...
Call should be routed  PSTN - Gateway - Pilot number - Hunt group broadcast (number1,number2)
Where in trace I can found information how call really routed...
I found in
Subscr\c\Program Files\Cisco\Trace\SDL\CCM
file SDL002_100_000189
I can see what call routed from pstn to pilot number...
gpn.nd=92189xxx cgpnVM= cgpnVMCSS= cgpnVMP= dialedDig= cdPart= cdPat= cdpn.tn=4 cdpn.npi=1 cdpn.nd=1xx0
but I have not information about following call routing n hunt group)
Which file I should look to find this information?
Thank you very much...
2 ACCEPTED SOLUTIONS
VIP Super Bronze
you need SDI traces not SDL
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
SDI trace files are located under the following folder
C:\Program Files\Cisco\Trace\CCM
These are txt files and their name begins with ccm. You can sort them by date / time.
Manish
VIP Super Bronze
Yes, I know this...
But CM version is 4.1... It my first meet with 4.1
After collecting trace I can not find any SDI associated files...
traces configured exact as described
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094e89.shtml
Can any comment this problem?
Please make sure that you are looking for traces on the server to which the phones are registered. If the trace settings are correct then probably a server reboot is a good option for now.
Manish
Hello, Manish! Can you provide any comment's for this solution? You suspect what SDI trace not collected by software error, what should be resolved after server reboot?
Thank you very much!
The callmanager service is responsible for generating ccm traces, so if the traces are not being generated for some reason then a reboot should take care of the issue.
Manish
Manish, some question else...
CM trace generate several files and folders... in files/folder tree where i can expect found SDI file trace? and what the name should be? ABOut CM 4.1...
Manish
Hello Manish!
Thank you very much! I have found  this files and now try to find information needed...
You can get some useful tips on reading SDI traces in windows callmanager versions from the following link
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080129d92.shtml#sditrace
Manish
252
