UCM 5.1 - system error code on the CDR "Error code 10011"
When trying to run reports, I'm getting the CDR 'Error Code 10011'. Tried to research on CCO but only came across this document:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080919416.shtml
This does not apply to my scenario. Does anyone else have any other suggestions?
-N
Re: UCM 5.1 - system error code on the CDR "Error code 10011"
was this working before?
is this an upgrade?
have you verified all the CDR parameters are properly configured?
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Green
Hi N,
What is the eact version for CCM
DO you see records under process and preserve folder using CLI file list command?
System version: 5.1.2.3000-2
How do I find the process/preserve folder using CLI file list command?
224
