Community Member
UCM 6.0.1 Device Pool Missing MoH Fields
I do not see the "User Hold MOH Audio Source" or "Network Hold MOH Audio Source" fields when configuring a Device Pool. Were these fields removed in UCM 6.0? Thanks, Tim
1 ACCEPTED SOLUTION
Re: UCM 6.0.1 Device Pool Missing MoH Fields
they're under the common profile now
java
if this helps, please rate
java
www.cisco.com/go/pdi
java
java
Community Member
Thanks, I found it under Device --> Device Settings --> Common Device Configuration
209
