Community Member
UCM 6.1(2) Voice Gateway Support
I am currently working on a CCM V4.1(3) upgrade to UCM 6.1(3).
The UCM compatability Matrix no longer states which Voice gateways/versions are supported.
My CCM 4.1(3) has 4 x 2650XM MGCP controlled gateways. Can anybody confirm that they are supported with UCM 6.1(3).
thanks
Ian.
Re: UCM 6.1(2) Voice Gateway Support
yes, shows up as 26xx series
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
Thanks for the update. Any idea on the recommeded Ver of IOS for the 2650XM.
thanks
Ian.
look here:
Cisco Unified Communications System Release Summary Matrix for IP Telephony for Enterprise and Midmarket
http://www.cisco.com/en/US/docs/voice_ip_comm/uc_system/unified/communications/system/versions/IPTMtrix.html
java
java
152
