UCM 6.1 - co-located IPCC
I have a running UCM 6.1 installation that has been commisioned recently. I am trying to load the IPCC 5 seater version that comes with the server. Do I need any downtime to load this software on to the UCM server ?
Whare can I find the installation instrucitons ?
1 ACCEPTED SOLUTION
Re: UCM 6.1 - co-located IPCC
You can have a look at the followng link -
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/custcosw/ps5693/ps1846/product_promotion0900aecd8029cff2.html
Table 2 gives a list, depicting in which cases a dedicated CCX server will be required.
-> Sushil
Hi NALAKA,
You are referring to the IPCCX 5 seat bundle wihch comes as a promotion with CUCM 6.1.
This can not co-recide on the call manager server.
You need to have a dedicated server for this installation, since its still windows based and your CUCM is linux based.
-> Sushil
-> Sushil
87
