UCM 6.1 SIP config for Opentext Rightfax 9.4
We are deploying a fresh install of Rightfax 9.4 with an SR140 virtual Brooktrout board that speaks to our UCM 6.1 via SIP. I have no idea how to configure the SIP connection on the UCM side. Any ideas?
Also, I have a block of 300 DIDs to use for my Rightfax server. Do I through these on the same Trunk Group as my existing phone DIDs? If so, how do I configure these fax numbers to see my Rightfax server via SIP.
Just a little confused here ;)
1 REPLY
Re: UCM 6.1 SIP config for Opentext Rightfax 9.4
The SIP should be easy to set up. Give it the device pool and SIP settings for a normal gateway.
The only real thing you need to worry about are these things:
-Make sure Rightfax is sending the SIP to an IP address and not a domain name
-The remote IP address at the bottom of the trunk is the source IP of Rightfax
-The Calling Search Space assigned to the trunk has access to the right partitions to call what you want.
The routing of your DIDs is going to be done through a route pattern that points towards your SIP trunk.
-nick
408
