UCM 6.1 Xcode/Conf Resources
balitewiczp
Level 2
Level 2
cannot get hardware conference/transcode resources to register. sccp shows up, cause code is tcp_conn_error. Used same process I use in CM4.2 DSP's are up.
no sccp/sccp doesnt help. Selecting IOS Enhanced in UC6.1 Thoughts are welcome
7 Replies 7
thisisshanky
Level 11
Level 11
Can you paste your SCCP configs
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
CNHKGNRT301#sho sccp
SCCP Admin State: UP
Gateway IP Address: 172.21.125.130, Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 10.5.139.197, Port Number: 2000
Priority: 2, Version: 5.0.1, Identifier: 2
Call Manager: 10.5.135.196, Port Number: 2000
Priority: 1, Version: 5.0.1, Identifier: 1
Transcoding Oper State: ACTIVE_IN_PROGRESS - Cause Code: TCP_CONN_ERROR
Active Call Manager: NONE
TCP Link Status: NOT_CONNECTED, Profile Identifier: 2
Reported Max Streams: 8, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: g729br8, Maximum Packetization Period: 60
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Conferencing Oper State: ACTIVE_IN_PROGRESS - Cause Code: TCP_CONN_ERROR
TCP Link Status: NOT_CONNECTED, Profile Identifier: 1
Reported Max Streams: 32, Reported Max OOS Streams: 0
CNHKGNRT301#sho sccp ccm gr 1
CCM Group Identifier: 1
Description: None
Binded Interface: Loopback99, IP Address: 172.21.125.130
Associated CCM Id: 1, Priority in this CCM Group: 1
Associated CCM Id: 2, Priority in this CCM Group: 2
Associated Profile: 2, Registration Name: APHKXCODE
Associated Profile: 1, Registration Name: APHKCFB
Registration Retries: 3, Registration Timeout: 10 sec
Keepalive Retries: 3, Keepalive Timeout: 30 sec
CCM Connect Retries: 3, CCM Connect Interval: 10 sec
Switchover Method: GRACEFUL, Switchback Method: GRACEFUL_GUARD
Switchback Interval: 10 sec, Switchback Timeout: 7200 sec
Signaling DSCP value: cs3, Audio DSCP value: ef
sccp local Loopback99
sccp ccm 10.5.139.197 identifier 2 priority 2 version 5.0.1
sccp ccm 10.5.135.196 identifier 1 priority 1 version 5.0.1
sccp
sccp ccm group 1
bind interface Loopback99
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 2 register APHKXCODE
associate profile 1 register APHKCFB
dspfarm profile 2 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729br8
codec g729r8
maximum sessions 4
associate application SCCP
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 4
What are the names of the resouces in your callmanager? Are they APHKXCODE and APHKCFB?
Does the names match in CUCM as specified in IOS configs
Sankar Nair
You would think to CCIE Voice guys would have something better to do!!!
Also - Use standard IOS and not enhanced!
Yep, names match exactly. Tried Standard, same problem. Is "no sccp / sccp" the correct way to reset from cli? Maybe its an IOS problem. version is 12.4(9)T7
I have the same problem.
