Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
UCM 7.0.2 and Attendant Console
I have a fresh install of UCM 7.0.2, not from an upgrade. I'm trying to get Attendant console running. Will this work or does it have to be a system upgraded from a previous version for attendant console to work?
Justin
Hall of Fame Super Red
Re: UCM 7.0.2 and Attendant Console
So as I read that thread the only people that have got AC to work on 7.0.2 were on systems upgraded from another version. Mine is a fresh install am I out of luck?
Unfortunately you can only choose from any of the new ACs, old AC has already been removed from CCO for download which could also be used for new installs.
As of April 17, 2009, the Cisco Unified Attendant Console is no longer available to NEW Unified CM 7.x installations.
java
if this helps, please rate
java
www.cisco.com/go/pdi
I have the software it just wont work. What I need, to satisfy my boss, is some sort of verification that it will or will not work with 7.0.2.
Justin
146
