11-15-2010 11:25 PM - edited 03-16-2019 01:56 AM
Is there a way to change the forwarding of a number when not on a phone attached to the Cisco UCM cluster?
For example let's say currently DID 650-555-1234 which goes to UCM forwards to my cell phone at 650-444-5678,
Now my shift is over and I want 650-555-1234 to forward to my friend Bob at 650-333-9012. Is there a way I
can do this without logging into the UCM with the web browser? That is could I dial a number and enter some
codes to change the forwarding? How would you set this up? Thank you.
Solved! Go to Solution.
11-16-2010 04:24 AM
We do not provide anything like that in CUCM, if possible at all, it would mean you would need to write down a customized IVR script which not only gathers the info you send via DTMFs, but also is capable of doing a lookup request based on the DN you would need to type down you want to change and then using XML/SOAP or some other method the write request to CUCM's DB to change this in the numplan table.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
11-16-2010 04:24 AM
java
11-16-2010 09:00 AM
Thanks.
