02-17-2009 01:35 PM - edited 03-15-2019 04:17 PM
UCM7 has phones in the same cluster in which calling phone to phone does not display calling name, only number. Corp directory local to box. Any ideas where to look?
Solved! Go to Solution.
02-17-2009 01:39 PM
corporate directory has nothing to do this this. Ensure the "display" field is populated under the DN on phones, also "alerting name" will provide the name to the calling party while the phone is in alerting state (ringing).
HTH,
Chris
02-17-2009 01:39 PM
HTH,
Chris
02-17-2009 01:45 PM
that was it, thanks for the quick reply
