UCM 7, copy active to inactive
Performed a successful upgrade to UCM 7.12, and the active partition is 7.1.2, but inactive is older 7.0.2.
Is there a CLI that will copy active to inactive? Or a procedure? thx
1 REPLY
Re: UCM 7, copy active to inactive
This is normal.
Next time you upgrade 7.1.2 to an ES or major release, current 7.1.2 on active partition will become the inactive partition.
Inactive partition will have the most recent version you were running before upgrading.
HTH.
144
