08-14-2012 07:11 AM - edited 03-16-2019 12:42 PM
hello All
I have a 10 server cluster running ucm 7.1.3 32900-4
when i try to run a backup the DB errors out at 50%
/bin/tar: -: Wrote only 4096 of 10240 bytes
/bin/tar: Error is not recoverable: exiting now
CCMDB Backup failed, unable to tar data to master agent
there is a bug for this error
however it's supposed to be fixed in our curent version
do you know any SFTP servers that will allow me to modify the parameters stated on the bug ?
freeftp is not an option
solawinds (free version) doesn't work quite well
I'really appreciate your help
thanks
08-14-2012 07:15 AM
06-06-2014 12:40 PM
This server works perfecto but you have to modify the SSHTimeout to 1200 at least, else youl get this error:
/bin/tar: -: Cannot write: Broken pipe
Restoring CAR services ...
08-14-2012 07:19 AM
Try to see this in Disater Recovery System Admin Guide
To back up data to a remote device on the network, you must have an SFTP server that is configured. Cisco allows you to use any SFTP server product but recommends SFTP products that have been certified with Cisco through the Cisco Technology Developer Partner program (CTDP). CTDP partners, such as GlobalSCAPE, certify their products with specified version of Cisco Unified Communications Manager. For information on which vendors have certified their products with your version of Cisco Unified Communications Manager, refer to the following URL:
http://www.cisco.com/pcgi-bin/ctdp/Search.pl
For information on using GlobalSCAPE with supported Cisco Unified Communications versions, refer to the following URL:
http://www.globalscape.com/gsftps/cisco.aspx
Cisco uses the following servers for internal testing. You may use one of the servers, but you must contact the vendor for support:
•Open SSH (refer to http://sshwindows.sourceforge.net/)
•Cygwin (refer to http://www.cygwin.com/)
•Titan (refer to http://www.titanftp.com/)
Leonardo Santana
