Community Member
UCM BE 6.0 - Not able to hear Voice Messages
We are running CallManager 6.0 Bussiness Edition with unity connection 2.0.
We are facing a problem like, i am able to keep the voice message and MWI also shows up.But when i press the message button to retrive the message,it says "currently extension 99999 is not availabe". I am able to keep voice message on all phones, but not able to hear the voice messages(but..voice message icon displayes on the ip phone)
Please help me out !!
regards,
1 REPLY
Re: UCM BE 6.0 - Not able to hear Voice Messages
do you have an schedule that allows you to do so?
that extension is the one from the EAdmin, do you have a routing rule for direct calls that could be causing this?
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
106
