Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
UCM BE 6.0 Presence problem
We are unable to see basic onhook/offhook presence information from directory lookups or missed calls. The only way we can see prescense onhook/offhook status is when we create a BLF line.
We have many 7911's and a few 7960's. Do the 7911's allow for presence?
any ideas of why BLF line on 7960 shows status but Directory and missed calles do not? All phones have been put into the same presence group, all have same partition and same CSS (for both device/line/presence subscription.
thanks in advance,
Re: UCM BE 6.0 Presence problem
any ideas?
Hi Did you manage to sort this issue, i have the same issue on a callmanager 6.1.2 install no presense on missed calls. I have it working on an earlier release of UCM with no issues.
Dave white ccie 13955
Presence capabilities for call history lists are supported for both SCCP and SIP on the following Cisco Unified IP Phones:
Cisco Unified IP Phones 7941G and 7941G-GE
Cisco Unified IP Phones 7961G and 7961G-GE
Cisco Unified IP Phones 7970G and 7971G-GE
The Cisco Unified IP Phones 7905G, 7906G, 7911G, 7912G, 7940G, and 7960G do not support presence capabilities for call history lists.
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
hi i have the 7961 phones and the 7970, looked at the config on the phones and they have been added as 7961, their is also an option for 7961g ge ? is this just for the gigabit phone, or should i be adding the 7961G as a G-Ge also ?
if it's gigabit add them as G-GE
javalenc
java
they are just 7961g phones not gigabit, should the 7961G be good for presense.
it's on the list of supported phoned i already posted
javalenc
java
must be an other issue then, maybe a tac call. Can you think of anything else it may be.
have you enabled the Enterprise Parameter "BLF For Call Lists"?
javalenc
java
i have enabled this parameter and reste all the phones in the cluster. Still no BLF for call lists. I have created a presense group and put all phones in it. The suscribe calling search space is set to a CSS that allows access to all partitions and phones.
Thanx for posting this info as you just saved me several hours of research. But I am curious, where is this info posted on CCO? I was looking at the Cisco Unified IP Phone Administration Guide for Cisco Unified CallManager 5.0 (SCCP) Cisco Unified IP Phones 7960G/7940G, and at the top of page 5-12 it says: Presence-enabled directories - Allows a user to monitor the call state of
another directory number (DN) listed in call
logs, speed-dials, and corporate directories.
The Busy Lamp Field (BLF) for the DN
displays the call state.
Am I reading this correctly that the 7940/60 phones can display BLF for call logs and corporate directories? Or is it old info?
Thanx for you help.
250
