UCM Export Find and List Phones Records?
I want to create a phone book based on all of the current subscriber directory numbers.
With that I want to edit in Excel where I can sort to look for unassigned extensions in order for me to test and see if they're in service. From there I can update my DID list on a separate spreadsheet to keep a list of available DID's I can use.
Is there a way to export in CSV directly from UCM? I'm basically highlighting and copying but it copies all of the hyperlinks and check boxes.
Thank you for any help in advance, I greatly appreciate it.
  • IP Telephony
Use BAT for thar purpose
java
if this helps, please rate
www.cisco.com/go/pdi
Hi Jaime, I've never used BAT
Hi Jaime, I've never used BAT for this purpose. Can you advise of an instruction I might be able to review?
Thank you
BAT docs are online, look in
BAT docs are online, look in maintain and operate
www.cisco.com/c/en/us/support/unified-communications/unified-communications-manager-callmanager/tsd-products-support-series-home.html
java
28
