UCM-LDAP Integration (sn attribute)
I'm trying to integrate ccm 9.1 with ldap for a 6000+ user base where ~90% of the user accounts have no (sn attribute). Would it be possible to import user account by pointing to a different attribute (e-mail address?)
Sharif
1 ACCEPTED SOLUTION
VIP Super Bronze
Sorry Sharif, the 'sn' attribute is required and there isn't an override option for it. You can only add additional constraints through the custom LDAP filter and the LDAP Search Base. Time to do some housekeeping in LDAP! While on the topic, don't forget to populate telephoneNumber or iPhone with a *unique value* for each user. Jabber doesn't do so well with multiple matches.
Please remember to rate helpful responses and identify helpful or correct answers.
Hall of Fame Super Silver
Do you want to use the attribute as user ID?  If so you can use one of the following:
sAMAccountName
mail
employeeNumber
telephoneNumber
userPrincipalName
HTH,
Chris
Hi Chris, thanks for your reply!
The problem is that whenever I synchronize with ldap, I get ~500 accounts out of the 6000.
Most user accounts created in active directory are missing data in the "sn" attribute, so they're skipped..
What I'm hoping to do is to synchronize using a populated attribute if possible?
Sharif
VIP Super Bronze
222
