UCM Log in
If I create a user id which includes letters as well as numbers, how do I set up the phone to allow the login? Currently I can only seem to use numbers at the login prompt.
Also, if this is possible, can you manipulate the keys to supply the letter related to the key after the number option? (ie push the "3" key once for a 3 and push it four times for an "F".
1 REPLY
VIP Super Bronze
Re: UCM Log in
There is an Alphanumeric User ID service parameter on the Extension Mobility service. Set that to true and you'll be able to enter letters in the username.
Please remember to rate helpful responses and identify helpful or
282
