Community Member
UCM upgrade from 6.0 to 6.1
i am running 6.0 and i would like to upgrade to the latest build of 6.1 I would like to have the ability to switch back to version 6.0 if i need to. The issue is that you can't upgrade from 6.0 to 6.1 ES build directly. You need to use the initial release of 6.1 then upgrade to the latest ES. Once i upgrade to the latest ES i will lose the ability to switch back to a 6.0 version. What can i do about this?
Jim
Re: UCM upgrade from 6.0 to 6.1
unfortunately as you mention you can only have 1 level below the current version to go back, so there is no way to have it as you want to switch between 6.0 and a 6.1 ES version, you will only get to switch to the base 6.1 version and the ES version
if for whatever reason you feel you might need to go back to the 6.0 version make a backup of it before doing the upgrade.
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
so there is no way that TAC can send me a file to upgrade directly to 6.1.1.2105 from 6.0?
Jim
the fact is that in many cases there are no such files, that's why you need to install the base version and then apply the ES.
the same applies if you need to install a new server on a cluster where there is an ES, you get the option to apply an SR or ES during the install for this same reason. but you need to initiate the install with the base version DVD and then apply the patch.
if DEV does not creates such files there is no way TAC can provide them
javalenc
java
Community Member
[quote]the same applies if you need to install a new server on a cluster where there is an ES, you get the option to apply an SR or ES during the install for this same reason. but you need to initiate the install with the base version DVD and then apply the patch.[/quote]
How does this work on an existing build and you need to apply an ES.
I can find no sensible documentation?
Rebuilding a cluster to apply an ES can't be right?
So, How does one apply an ES he has in ISO format, burnt to a CD?
go to the OS admin and apply the patch from there
there's a menu in there to do that
upgrade/patch should be the option
and there is a place where you can find the information on how to do this, it's the README file.
javalenc
java
Hall of Fame Super Red
Hi Neil,
You can access the patch file from either a local disk (CD or DVD) or from a remote FTP or TFTP server.
From this excellent doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/6_1_1/cucos/iptpch7.html#wp1052939
Hope this helps!
Rob
137
