UCM upgrade from version 5.1 to 7.1 compatability
Can anybody please help me with an upgrade question.
I have client running version 5.1.3.5105-1
They wish to upgrade to version 7.1 and have ordered the relevant upgrade from cisco, i am wondering how the compatability matrix works, all the mentioned 5.1 releases refer to ver 5.1 (3a) , 5.1(3b) etc, how does this relate to the software i have above 5.1.3.5105-1.
Also i see in another post somebody mentioned that you require the full install disks from the 7.1 load to upgrade from version 5.1 is this true, can i not use the ISO files ?
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html
Hall of Fame Super Red
Re: UCM upgrade from version 5.1 to 7.1 compatability
Hey Dave,
Hope all is well
This version is an Engineering Special based on 5.1(3d) I believe, it shows up in
the Downloads area on CCO as 5.1(3.5101.1).
You will require the Install Media to perform this upgrade as the .iso files
won't do the trick here. You should receive them as part of the upgrade order.
Cheers!
Rob
There are no fresh install files available to download, they're just for specific upgrade paths. Fresh install requires you to order the media.
You can order the upgrade kit via the PUT.
You're running a ES that is based on 5.1(3d)
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hi Guys
Thanks for the post, so the version i have is a version of the 5.1.3.5100 train, does it mention the 3d bit when you go into the release notes. I'm still confused about the upgrade bit, we have the media as part of the upgrade kit, i thought media was for a fresh install ? are you saying i also use the media for an upgrade also ?
Rob just to confirm you also saying the ISo files cannot be used for upgrade ?
regards
dave white
ccie#13955
Hi Dave,
You definitely need the Upgrade media for this type of migration. The .iso
files are only for a qualified 7.x to 7.x upgrade.
You will see this in the proper 7.x release notes. I will try to find the reference
later, as I am on my way to another meeting
Cheers!
Rob
Hi rob
Sorry to be a pain, might be a simple question this one. Is the
upgrade media and new install media the same thing or are they
different ? I think this is were I am getting confused, I do now
understand the iso bit in version upgrade thanks for clearing this up.
David White CCIE #13955
Technical Consultant
s2s Limited
An NG Bailey Company
David.White@s2s.ltd.uk
T:08703504525
F:08703504526
M:07525124161
Sent from my iPhone
On 10 Feb 2010, at 15:45, "rob.huffman"
Hi Dave,
Not a pain at all my friend
This is the same media, it can be used for upgrades from compatible
versions as well as "new builds". It's just a terminology thing.
Be careful if you are going to 7.1(3) and make sure to add the latest updates.
Release Notes for Cisco Unified Communications Manager Release 7.1(3)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/7_1_3/cucm-rel_notes-713.html#wp1710155
We don't want you hitting this;
CSCtc81478 Bug Details
Timezone wrong on 3rd gen phones after upgrade from 5.1.3 to 7.1.3.
Symptom:
After UCM is upgraded from 5.1.3 to 7.1.3 the 3rd Gen phones will
display incorrect time. They will always show GMT time.
Conditions:
This only happnes if you upgrade directly to 7.1.3 from 5.1.3, the timezone tables are not marked as legacy as they should be
releated to defect CSCtc52241
Workaround:
DE will post Workaround via root or you may be able to upgrade to 6.1.3 then 7.1.3
need to confirm that     Status
Fixed
Severity
1 - catastrophic
Last Modified
In Last 3 Days
Product
Cisco Unified Communications Manager (CallManager)
Technology
1st Found-In
Fixed-In
7.1(4.6)
7.1(4.5)
7.1(3.11002.1)
7.1(3.20000.2)
7.1(4.98000.45)
8.0(0.98000.76)
7.1(4.7)
7.1(4.8)
7.1(4.9)
7.1(4.10)
7.1(4.11)
7.1(4.12)
7.1(4.13)
7.1(4.14)
7.1(4.15)
7.1(4.16)
7.1(4.18)
Hope this helps!
Rob
Hi Rob is it likley that i will receive the 7.1.3 disks from cisco as part of the upgrade we have ordered ? if i do will i have to ask cisco for older disks as per the recomendation not to upgrade from 5.1.3 to 7.1.3 ?
dave
i might be ok as i'm in GMT UK
393
