UCM ver 7.0.1.11000-2 and DST patch Nov 2009
Does anybody knows if I need to apply a DST patch for this particular Version of Call manager, if so what is the patch description, thanks
Re: UCM ver 7.0.1.11000-2 and DST patch Nov 2009
Please refer to the following link:
http://www.cisco.com/en/US/ts/fn/632/fn63213.html
But to answer your question, you need to be running at least 7.0.1.11002-1 or 7.0.1.21022-2 or higher.
Hope that helped, if so please rate.
So does this means that I can apply the patch or I dont need to apply any patch to my cluster?
You will need to upgrade to one of the versions that I mentioned or higher. To be safe I would just go with the latest version of 7.0.1.
so in few words i will need the DST patch, but before i do that i will have to upgrade the version of my cluster
127
