UCM6.1 Route Groups and SIP Trunks
I have the following case:
I need to configure a route group that contain 3 SIP Trunks, however in the Rout Group configuration page the SIP Trunks are not listed under the availabe devices. I'm using UCM 6.1.5.10000-10
However, in UCM 7.1 I do have the SIP trunks listed under the available devices for the Rout Group configuration page!
Dose any one have this limitations also?
1 REPLY
Super Bronze
Re: UCM6.1 Route Groups and SIP Trunks
If you have a Route Pattern pointed directly at the Route Group, it will be hidden - remove the RP, and you'll be able to add it to a route group.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
302
