UCM6 database question
Hi Chaps, easy question
UCM6 - is it a SQL backend database that is used? if so - during a new installation is it possible to host the sql database on an external (corporate) SQL server?
Thanks in advance.
Rod
  • IP Telephony
1 ACCEPTED SOLUTION
Re: UCM6 database question
no, windows versions use SQL, linux versions use informix.
cannot be hosted on any other server
java
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
java
java
105
