Community Member
UCM701 SNMP Master Agent not running
Hi, I have UCM 701 installed in a VM with 2 processors and 2gb RAM as a Demo/Test System. The only thing giving me a hard time is the 'SNMP Master Agent' which is not starting after all configs like community etc. have been set. The same procedures in V6 worked fine and UCM responded to SNMP queries.
Patrick Geschwindner, Ascolta
Community Member
Re: UCM701 SNMP Master Agent not running
Hi Jon,
didn't run into your post, even searching for 'SNMP master agent'. This solved it !!thanks for the quick reply.
cheerio
Patrick
193
