11-06-2013 06:24 AM - edited 03-16-2019 08:15 PM
We are planning a UCS deployment with a mix of Cisco UC and non-Cisco VMs. Some of our apps support full co-residency, while others support UC with UC only.
For the UC with UC only, I assume that is only per UCS blade? I can put non-Cisco VMs within the same vCenter data center, as long as they are on separate physical blades (same chassis)?
Thanks, Bill
Solved! Go to Solution.
11-06-2013 07:00 AM
Correct, on B-series that is per blade.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
11-06-2013 07:00 AM
java
