UCS Server Co-residency question
We are planning a UCS deployment with a mix of Cisco UC and non-Cisco VMs.  Some of our apps support full co-residency, while others support UC with UC only.
For the UC with UC only, I assume that is only per UCS blade?  I can put non-Cisco VMs within the same vCenter data center, as long as they are on separate physical blades (same chassis)?
Thanks, Bill
1 ACCEPTED SOLUTION
Correct, on B-series that is per blade.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
1 REPLY
java
java
127
