UCS200M2 Raid configuration
     I have a ucs 200m2 that has a single HDD.. When I try and configure raid it does not have option to do any configurations with a single drive. This model is supported with a single drive according to spec sheet but when you do the ctrl "q" to configure the drives it will not let me.. There is only options for configuration with two drives or more, Anyone seeen this? Is maybe the wrong controller ? I cannot find anything on it.. I am getting at least one additional drive,
1 REPLY
  The RAID would not have any other option because you can only RAID when you have two or more discs.  Once you add the other drive you can set the RAID.  I would recomend Mirroring.
Anthony
211
