UK E1 PRI
Hello:
When adding E1 PRI for UK using MGCP what would be the PRI protocol type?
2 ACCEPTED SOLUTIONS
Hall of Fame Super Red
Re: UK E1 PRI
Hi Rajesh,
Hope all is well! You should check with the Service Provider but it may well be;
isdn switch-type primary-net5
Hope this helps!
Rob
Re: UK E1 PRI
I normally use PRI euro and never had any problems so far touch wood...
Re: UK E1 PRI
Hi Rajesh,
Hope this helps!
Rob
Re: UK E1 PRI
Rob:
All is good, thanks for the information,
for be the "PRI protocol type" in the CUCM GUI page. Currently have following options and i guess it would be PRI-EURO
1. PRI EURO
2. PRI Australian
Re: UK E1 PRI
Re: UK E1 PRI
Hi Rajesh,
Sorry for the delay, I missed your reply completely :(
"PRI - EURO" should be just fine as nicely stated by Bruce. (+5 points for your good work here Bruce)
Take care buddy!
Rob
Re: UK E1 PRI
Rob & Bruce:
Thanks for your input.
263
