UK Number plan
Is thier any way to look at what numbers are included in the UK Number plan ?.
IE how can I tell if the new 0203 number for London is in the plan and other future numbers ?
With the NANP this is easy but the Route Plan report does not show this detail for the UKNP.
Thanks.
1 ACCEPTED SOLUTION
Re: UK Number plan
If you have already installed the IDP for UK then you can search for the Dialplan folder in C:\Program Files\Cisco and open the text file it will tell you what patterns are included.
You can also reference to a general UK dial plan here.
http://en.wikipedia.org/wiki/UK_telephone_numbering_plan
Sankar
PS: please remember to rate posts!
1 REPLY
Re: UK Number plan
Sankar
139
