05-11-2012 10:12 AM - edited 03-16-2019 11:07 AM
Hello guys!
I have a client that wants to be able to un-hang (I don' t know how to say it) the extension the person is dialing to. For example, if person A calls person B, but person B is not answering, caller A wants to be able to un-hang person B's extension and ask 'are you there' or something similar. The phones are 7942G and the CUCM is 8.5. How is this done? Thanks in advanced!
05-11-2012 11:43 AM
You need to look into Intercom feature for that.
HTH,
Chris
05-11-2012 12:40 PM
Thanks for reply. Will it be necessary to add the Intercom button to each phone in order to achieve this?
05-11-2012 11:44 AM
You can try intercom using the whisper feature, refer to the features and services guide for CUCM 8.5.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
05-11-2012 12:49 PM
Thanks for replying. If caller A is calling to main directory number of caller B, how can caller A invoke the Intercom on the same call? As far as I understand, in order to use the Intercom you have to dial the Intercom. Please guide me through this. thanks again.
