Unable incoming calls whit CUCM Subcriber
Hello
I have CUCM 6.1.5 Cluster, when the Publisher works the incoming calls works, but when the Subcriber is work the incoming calls no work.
Ihave this configuration of dial-peers on the gateway.
dial-peer voice 100 voip
preference 1
destination-pattern 21..
voice-class codec 10
session target ipv4:10.36.241.10 (IP Publisher)
dtmf-relay h245-alphanumeric
dial-peer voice 101 voip
preference 2
session target ipv4:10.36.245.11 (IP Subscriber)
Any idea about it.
Thanks a lot.
1 REPLY
Re: Unable incoming calls whit CUCM Subcriber
Follow this link to create the voice class for that purpose
H.323 Gateway Dial-Peer Configuration for Cisco  CallManager Server Redundancy
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080094852.shtml
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
115
