05-04-2013 09:33 PM - edited 03-16-2019 05:09 PM
Dear All,
We have complete licenses for phone,but still unable to add new phones in the Pub_CUCM 6X.
what are the possible reasons and how i can troublshoot this issue?
Solved! Go to Solution.
05-07-2013 09:53 PM
Hi Waqas,
Any error message which appears after u try to add IP phone 7911 from Publisher?
are u getting stuck with 7911 model only or other phones are also facing same problem.
regds,
aman
05-04-2013 09:45 PM
Hi Waqas,
Can u share which is the phone model u are trying to add in CUCM version 6.x?
Any error message which u get while adding phone.
regds,
aman
05-05-2013 12:15 PM
Hi Aman,
CUCM was stuck and unable to add phone and change partion and css .Now its Ok autometically.
Please find the attached logs collected during the registration of cisco 7911.
10.10.4.11 ccm_pubv 6.1.
10.10.4.12 ccm_sub
05-06-2013 10:35 AM
HI
I have also uploaded the trace and logs of 30/04/13.when problem happend at 4:30 pm to 5:00 pm.Please review the logs
05-06-2013 10:48 AM
What is the MAC address of the phone (to filter trace)?
What exactly is the error do you see on the CUCM page while adding? What happens when u click save
Does the phone auto register if you turn on auto registration?
Issue if for just one phone model?
05-06-2013 07:18 PM
Hi Waqas,
I had gone through the logs and could get following info:
a. about 350 IP phones are regsitered.
b. 5 number of MGCP Device Gateways are registered.
c. also, the DB replication is fine.
Can u let me know the DLUs available and phone model which u are trying to add with MAC address?
Also, mac -address of phone.
regds,
aman
05-07-2013 01:17 AM
HI
I checked DlUs are around 7000 remaing.
The phone model which we tried was 7911 and
Mac address for the phone with extn 8251 is 001f6c80e41c .
05-07-2013 02:15 AM
Hi Waqas,
Is there DHCP services ? DHCP enabled on the Phone ?
05-07-2013 02:27 AM
Hi Waqas.
Your 7911 is attempting to download 9.0.3 firmware from CUCM, but the actual version installed on your phone is older than version 8.5.2, necessary to upgrade to later version and CUCM is logging "File auth fail"
I suggest you to do an "offline" upgrade of 7911 to at least 8.5.2 version before register the 7911 to CUCM.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
05-07-2013 09:44 PM
HI Carlo,
Thanks ,ys i have plan to upgrade the device package because we also unable to add CP-7926G.
05-07-2013 09:40 PM
HI Deepesh,
Yes DHCP is enable on phones.Please review the attached 30.04.13 trace and logs.I want to know why cucm stuck on 30.04.2013 .Is there database issue?
05-07-2013 09:47 PM
Hi Waqas,
There is no DB issue since logs show count as GOOD.
I think u have created DHCP server on CUCM itself.
regds,
aman
05-07-2013 09:53 PM
Hi Waqas,
regds,
aman
05-07-2013 10:04 PM
HI Aman
Yes we got AUTH Fail message when we later test one of the 7911 phones.Its not for all phones.
Did you find any issue in 30.04.13 logs?
05-07-2013 10:37 PM
Hi Waqas,
I tried going through the logs but could not find any error related to adding phone.
for AUTH FAIL, u can try below procedure:
a. Please go to settings ----security configuration on IP phone?
b.Press **# to unlock phone and erase ITL file.
regds,
aman
