Community Member
Unable to add the IP-IVR in HA mode.
I get an error during the setup when I add the 2nd IVR server to the cluster .The error is "Add to Cluster is failed because of ClusterException Component CRS Repository database is enabled".
The Primary IVR server is installed as a First Node and is working fine and in production.
Could You please let me know as what needs to be checked here.
Also appreciate if there is a detailed guide for installing IP IVR in HA mode since it is not explained in detail in the installation guide of CRS 5.0?
Shams
Community Member
Re: Unable to add the IP-IVR in HA mode.
This issue has been resolved.
Pls do not reply to this.
Rgds,
Shams
Community Member
Hello Shams,
I'm facing a similar issue with the HA configuration
How did you solve it?
Ahmed
149
