Unable to block a incoming fraud number --in MGCP cluster
Hi all,
We have one incoming number which we need to block in our entire cluster.
We have MGCP gateway configuration.
We have multiple office with WAN connevctivity with their own PRI and VG
I tried playing with partition CSS and translation pattern blocking NO GO
And even we canot create any translation rule on GW as we do not have a h.323
So how do I block this one perticular incoming number calling our phones in all the regions.
is only contacting telco will fix this issue?
Rebecca...
Re: Unable to block a incoming fraud number --in MGCP cluster
Hi Rebecca.
If you are using a cenralized call processing model, you can add a translation pattern matching called number and select block this pattern or use a non existing destination as called party transform mask.
Put this translation pattern in css assigned to incoming calls on mgcp gateway config.
In case of a distributed call processing model, you have to add the above TP on all CUCM clusters.
Carli
Please rate all helpful posts "The more you help the more you learn"
Hello carli!!
Thx for u r reply..!!
we are having multisite with centralised dplymnt design
as we have only one pub with 2 sub's at one location and all the offices are connected over the WAN but they have their own PRI to make outgoing PSTN calls with own boardlines.
Could you share me the doc guide to configure above scenario? which will have one example atleast or steps
I tried multiple stuff and exausted
Do we need to create a translation and transformation patter for all the sites?
Rebecca..
Marry Xmas to all !!!!!
VIP Super Bronze
Please refer to this documentation, if you are running cucm 8 or above..
https://supportforums.cisco.com/docs/DOC-19628
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
We are on 9.1
I was going through the same link from yest
How to block Incoming calls in CUCM 8.x based on ANI with MGCP gateway
No Luck may be I am doing some thing wrong..
VIP Super Bronze
I suggest you review your steps again and follow the document step by step..It works..
Hello Rebecca
Refere to below link, method is the same however this one has more descriptive, Just try once looking into this.
http://ciscovoiceguru.com/6516/ani-based-call-blocking/
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
Hello Nadeem,
Tthe doc link which you have shared has unity connection configuration as well but we do not have unity connection at this moment
I only want to block one specific number for my office and the remote office
so I followed till half of the solution but no go...
Could you let me know till what steps i should follow. we have remote office i want to block it in remote site too as they have own PRI and even call should be blocked in remote office too.
Rebecca...
VIP Super Bronze
Please share your configuration with us..Please share the screen shots of what you have done....
Can you also do a debug isdn q931 for the number you want to block and send the out put here
249
